white exhaust smoke with a touch of grey
WOODWARD395
Lancashire
touran 1.9 tdi
ok got 1.9 tdi 105 77 with white smoke head gasket fine along with compression no coolant loss at all.
have changed injectors and all seals are new tandem pump changed and lash is set correctly torsion is "0"
smoke smells slightly of diesel :eek:
wanted to insert video and vcds readings but dont know how to do it when i do i will post.
any input is much appreciated.
greenskeeper
USA
1998 Jetta TDI
Cold start smoke?
All the time smoke while at operating temperature?
The latter could be late timing.
WOODWARD395
Lancashire
touran 1.9 tdi
its at all temperatures have checked timing but will check again tomorrow.
just wondering if a timing belt can stretch enough to cause it as timing was recently checked.
thanks for your input appreciated.
WOODWARD395
Lancashire
touran 1.9 tdi
checked timing belt today belt was spot on no deviation at all.
re checking turbo tomorrow for play and oil seals does anyone have a step by step instructions on setting up a vnt turbo using vcds thanks.
greenskeeper
USA
1998 Jetta TDI
i was wrong it started again at operating temperature under load.
It's been a while since I owed my TDI but if it's not a timing issue a faulty fuel pressure regulator on the IP could cause the smoke. It's located on the top of the pump, remove and see if the guts have fallen out.
Vince Waldon
Edmonton AB Canada
Unfortunately, "0" is also what the torsion will read if it's off the scale in either direction, so it can fool you.
Perhaps dial in some something just off-zero and see if it helps.
jmodge
Greenville, MI
If the above idea doesn't work (try that first), a faulty CPS could give a 0 torsion reading also
WOODWARD395
Lancashire
touran 1.9 tdi
hi found out its the ccv valve on cam cover faulty soaked cat and pipes gave smoke similar to turbo gone or injector problem.:eek:
