[ QUOTE ]
I sent an email to TxDot about ULSD and the use of biodiesel in diesel fuel.He said that BD20 actually raises the NOx instead of lowering it...Someone please tell me the truth....Thanks...Bobby...obviously TxDot has no desire to use BD THATS FOR SURE!
[/ QUOTE ]
What? Texas doesn't want to use biodiesel?! Shocking!
Biodiesel can slightly raise NOx emissions. Of course, since it has no sulfur, it will be perfectly compatible with the NOx adsorbing catalysts companies will be able to start using in late 2006 once the high sulfur diesel can no longer be sold in the US (sulfur kills those catalysts, which can remove up to 95% of NOx emissions).
Of course, countless reports have shown that REDUCING NOx emissions in cities, as the EPA wants to do, will likely actually make smog worse. This is because cities generally have a surplus of NOx emissions (VOCs and NOx combine together to make smog. When you have an excess of NOx, or no VOCs at all, the NOx actually
destroys smog (NOx + O3 -> N2 + O2 essentially (yes, I know it doesn't balance. I simplified it for here)). So, the surplus NOx that cities currently have is actually destroying some smog. Reducing NOx emissions will end up making smog worse - unless VOCs are reduced far far more.
See
http://www.osti.gov/fcvt/deer2000/lawsonpa.pdf
Page 15 has a nice ozone isopleth diagram showing a city in California at various points in time, its NOx and VOC levels, and smog level (indicated by color). Reducing NOx levels would move the city downward on the graph, into a higher smog region.
On page 18 of the presentation - "Analyses suggest South Coast Air Basin is hydrocarbon-limited with respect to ozone
formation, i.e., major NOx reduction programs will likely increase ozone formation and make it more difficult to attain the ozone standard".
That's essentially true of every city in the US.
