subber598
- Joined
- Aug 9, 2018
- Location
- New Hampshire
- TDI
- 2014 Jetta Sportwagon TDI, 2013 Passat SE, 2011 Jetta SEL
Hi everyone I'm a newbie, so excuse me if I mess-up my first post. I need to replace the right front strut spring and in that process, replace the axle bolt. What's in my car is the hex head which requires the stronger torque at 148ft lbs + 1/2 turn, so I'm thinking why not use the 12-pt which only needs 52ft lbs + 1/4 turn. Will this work when the left wheel has the hex bolt? I've seen where the 12-pt with the smooth flange and the one with the ribbed flange have different torque values, and I'm wondering if this is a reality.
Also would like to find a good source for these bolts and ant others that I may need for this repair; I'd like to have everything all set before thrashing and banging. thanks in advance.
