TDiMike
Tis the season to be mounting roofracks if you're a skier/snowboarder, and so I thought I'd pass along a few tips for those looking into racks and then trying to mount em etc.
1) Why OEM racks? What about Thule or Yakima? The main reason is because these bars have a really good connection system than attaches right on to the unibody of the car. The also include the locks at no extra charge, and include the clear plastic strips to protect your paint, heck they even give you a torque-wrench tool to put them on. Finally, the price is competitive if not less that Yakima Q towers/bar or the Thule aftermark system. Rumour has it that VW has Thule make the OEM racks for them.
2) The OEM rack comes with clear directions, so I won't go into detail on how to mount them. You can buy an OEM ski carrier or get a Thule one. If you get the Thule one, make sure you get the "T-bolt" package so you can mount them. I believe Thule calls this the "FastTrack" system. Basically they're bolts with a base plate which slides through a groove in the top of the bars. The bolts stick up and you just line up the hole on the ski carriers, or bike tray or kayak carrier and then secure it with the nuts provided with the t-bolt package (no tools required).
3) Take em off if you're not using em. Racks are exposed to elements and take a beating and hurt gas mileage. If you're not using them all season, take em off.
4) There's a rubber strip included with the OEM racks, which fits into the groove where the t-bolts go. This strip is handy if you want to put some lumber or canoe up there and not have it slide around as much. It also minimize the hum from wind. Wind noise is at it's worst when the bars are empty, but the strip does help. When you mount it, DO NOT try and slide it, but rather just put it on top and push it down into the groove. Work your way from one end to the other and you'll find it's much easier than sliding it in. With my ski carrier, I have part of the bars' groove left open due to length of the carrier, so I cut this stip to fir in the remainng space. I can just mount both piece of trim in the racks should I take the carrier off, so no big deal.
5) If you love fairing and their look, and ski racks, don't go for OEM bars - it just doesn't work out. Go for yakima. I'm unconvinced that there is much noice or fuel economy savings with a fair in our cars.
Anyways, hope this helps those on the fence etc. Here's the final product:
