vwdsmguy
As it says I installed this Colt stage 3 cam in my already modded ALH. It needed the lifter bores to be relieved some, but otherwise it's a drop in with new lifters. The timing was set using the timing tools just as an OEM cam would be.
"Results may vary" - here are mine as a "seat of the pants" reaction. About 2 MPG less than stock cam with a very slight power loss on the bottom and a slight gain in the middle and top. 1/4 mile speed, after many runs before and after install is the same. Is there a better cam timing spec than stock?
Anyone got one of these and how's yours work?? Gotto be somebody with one.
