TDItus
2003 Jetta TDI Wagon 5-speed...
Four YEARS and a few months ago, I bought this car and drove it home on a 1500 mile trip. The engine ran flawlessly, and the Turbo was perfect.
At that time, I already had an identical 2003 Jetta Wagon, so I parked this one in my garage for "later use"... over the past four years and a few months I have started the engine at least a few times per year, and drove the car a few hundred feet or so now and then, but never above 5 MPH.
Yesterday I was going to take it for an actual "drive" on the highway and before I could get down my 200 foot driveway, the car just refused to rev up and started blowing bluish smoke like crazy. It idles perfectly, and doesn't smoke when idling, but will not rev up, and smokes like crazy if you try.
No CEL. Air filter is good. No water from the fuel filter drain. Intake is a little blackish but not terrible. No unusual amount of oil from the cooler. Oil does not appear to have coolant in it, and coolant does not appear to have oil in it. Turbo spins freely. Actuator rod for Turbo boost release/control I found to be very stiff, but loosened it up and no change in symptoms.
What the h__l happened while this car was sitting in my garage?
