grasshopper
P1850 and P1857? P0725 was the engine speed circuit which I replaced but the engine cut out while driving again and the fault lights came back on. The OTC Genisis scanner repeated the same codes as the first time. Before the speed sensor was replaced, I could drive the car but it was very slow to respond to the pedal movement and the engine would shut down if I did not treat it gently and slowly. Now that the sensor has ben replaced it has only died while driving once and it does not seem sensitive to fast movement of the pedal. It is a bit slow to respond to pedal movement however. Someone - Help! WHat is the problem and how much will this cost me? It is a full day trip to a dealer and back.
