Hi All,
Long time lurker. I finally bought my first TDI a couple weeks ago: 2001 MK4 Golf with the ALH engine code. Really stoked.
I bought it knowing it had issues. I'm pretty handy with a wrench and knew it was going to be a fun project.
Now for the problem.
Previous owner ran some dirty Bio diesel in it. He replaced the injection pump 2 years ago with a new unit. ALso replaced the fuel tank, lines and filter.
I pulled vacuum on the system at a couple spots and confirmed no issue. Even removed the fuel sender cleaned and poked inside the tank to see only minor debris.
I opend the IP, Quantity adjuster has a lot of contamination / rust / coil paint that has flaked off. Diving further into the pump, I removed the metering block (assembly housing the QA coil / cam / spring assy) and found the attached pictures. Looks like surface rust on the steel parts in there :/. Not super happy, but I realize this may just need a new pump. Since this really is a project, I would like to avoid the cost of an IP.
I have a IP seal kit coming in the mail.
Questions:
1) I would like to take the IP into pieces, ultrasonically clean and reassemble. Is there a procedure to do so? I searched, but haven't found anything.
2) Has anyone done this with success before?
3) Advise please?
Thanks!
Questions:
3) Advise please?
Thanks!
