Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI (Diesel) Emissions
TDI (Diesel) Emissions This is a discussion about emissions from TDI's. Pro's cons of Diesels (including biodiesel) effects on the environment and how they compare to Gasoline and other fuel sources for Internal combustion engines.
Old September 22nd, 2018, 10:16   #1
1234vic
TDI(s): 06 jetta TDI
Default 2006 Jetta tdi engine Rattle
have a 2006 jetta tdi with 232k miles.
When at idle, I have this awful rattle from the engine compartment.
Could it be the egr cooler failure?
Please click on the link to listen to the rattle:
https://photos.app.goo.gl/FhNRmPzcWW1yMmkM7
Please advise.
1234vic is offline   Reply With Quote
Old September 24th, 2018, 20:25   #2
Dominicdx
Fuel Economy: 40-45mpg 600-630 mi.
Please advise.
Did you ever find the noise? I think I have the same one
Dominicdx is offline   Reply With Quote
Old September 24th, 2018, 21:08   #3
1234vic
Default Rattle
Yes on another forum was suggested that is "dual mass Flywheel", please google this and you will confirm, most likely is the flywheel failure, hope that helps
Old September 25th, 2018, 03:29   #4
Dominicdx
Default Noise
Did you replace the flywheel?
If so how much did everything cost
Old September 25th, 2018, 10:28   #5
1234vic
Default Rattle
No, i have not replaced it yet, i looked for the parts on the net and was anywhere from $250 to $400, dealer wants $800 parts only, i imagine its probably a $700 minimum total. ( $350 for installation?)if you have a private mechanic install, it's a wild guess!
Look at the videos i don't think is that difficult
Old September 25th, 2018, 11:07   #6
Dominicdx
Default Transmission
Is your automatic or manual?
Old September 25th, 2018, 14:23   #7
1234vic
Default Rattle
Auto dsg
Here is a video that will help you.
https://www.youtube.com/watch?v=35jz...ature=youtu.be
Old September 26th, 2018, 09:26   #8
andreigbs
I would venture to ask if you know the status of the camshaft and lifters.
BRM engines were notorious for failed cams and lifters, resulting in horrible idling and overall performance.
I would advise a search and read on "PD camshaft wear."
2014 Jetta TDI // 18xxx miles // 41 MPG & 2014 GLK 250 // 87xxx miles // 36 MPG
2014 Golf TDI // 45xxx miles // 38 MPG - buyback'ed
2004 Bora TDI // 146xxx miles // 42 MPG - sold
1997 Jetta TDI // 317xxx miles // 44 MPG - sold
1986 Golf Diesel // 224xxx miles // 48 MPG - totaled
andreigbs is offline   Reply With Quote
Old September 26th, 2018, 10:02   #9
1234vic
Default Rattle
That i don't know,i own the car since 2007 had 10k miles. The motor sounds fine, when i searched for flywheel problems, the rattle on YouTube, that was the same noise.
If the engine is below 1200 rpm, we can hear a knocking sound, the car has 232k miles.
I believe is the flywheel, but thanks for the tip
Old September 30th, 2018, 14:06   #10
andreigbs
If it is the DMF, I would tend to it sooner rather than later. If it grenades, it won't be pretty.
And since it's a BRM, I'd take a peek under the valve cover just for my peace of mind.
Good luck.
Old September 30th, 2018, 14:43   #11
Dominicdx
Transmission shop said it wasn’t the DMF.
I’m going to delete the EGR Valve & Cooler to start.
Does he valve cover go bad? Or are you just saying to check the internals?
Old October 1st, 2018, 12:36   #12
andreigbs
Honestly, deleting emissions-related parts isn't likely to resolve your issue; I'd leave that for later.
What I meant by peeking under the valve cover is examine the valvetrain, especially the camshaft and lifters. Look for worn down or scratched lobes, cracked or spider-web patterns on the lifters. Better yet, take some pics and post here.
The valve cover does not typically go bad, just don't over-tighten the bolts holding it on.
Edit: you may also want to create a link to this post in the "A5 TDI" section, where it will be seen by more folks than here. Cross posting is frowned upon, so you may want to just start a new thread there.
Old October 2nd, 2018, 12:14   #13
narongc73
If you have not ever changed the dmf, that is likely the problem. Have fun changing it I have done it twice and switched to manual with a smf instead.
narongc73 is offline   Reply With Quote
Old October 23rd, 2018, 19:20   #14
1234vic
Finally replaced Dual Mass Flywheel, parts cost with a few tools $400.
After new install, test drove, findings:
Low power
rough shifting
accelerating from 30 mph car started to Hick up, engine light turned on...
Not Good!!! anyone has this happen to them?
Please help
2006 Jetta TDI, DSG Rattle help Please! TDIER VW MKV-A5 Golf/Jettas 7 August 18th, 2015 19:36
2006 jetta tdi 1.9 rattle in oil pan smit5011 VW MKV-A5 Golf/Jettas 18 March 17th, 2013 18:03
bell type rattle at low RPM 2006 Jetta TDI monkeytrader TDI 101 7 March 8th, 2013 07:18
2006 Jetta TDi DMF DSG replacement - clunk rattle ecaddy TDI 101 12 March 20th, 2012 06:06
Page generated in 0.17982 seconds with 11 queries
[Output: 114.94 Kb. compressed to 95.70 Kb. by saving 19.23 Kb. (16.73%)]
