odet27
Hello, trying to change my tie rod ends and am having an issue with with a nut.
Check picture > wrench #1 (22mm) is on the stuck nut. As i try to turn it towards the back of the car to loosen it, the whole tie rod spins with it. Not sure if the inner boot will get messed up if i keep going? I noticed this and put a 13 mm wrench on the bar of the tie rod to try and hold while attempting to loosen the nut. Not much room for leverage here, putting all my strength will not move the nut, though I'm not very strong either .
I have penetrating oil (PB blaster and some other brand) and have soaked it in this. Also I used a map gas torch to try to heat it up.
Any one else come across this issue? May have to get some one more strong armed over to help me. Last thing I want is to round the nut from me slipping.
