the subject pretty much explains it all. During a flood today I was forced to proceed through about 1.5' deep water at some point. Worrying about being stuck at the deepest point i wound up 1st gear to get as much momentum as possible. I accidentally over-revved a bit but made it through. Immediately afterward I noticed the shield under the fuel tank was dragging against the ground. (the frictional force of the water must have torn it off!) but worse than that the engine was definitely bogging. After a few miles it smoothed over a bit and now builds power again but definitely isn't the same. The oil on the dipstick looks and smells normal (changed 400 miles ago) though when I looked in the valve cover this is what I found. Should I expect the worst? The car is still driving pretty well though now it has a very rough idle when cold. 268k miles 1Z
