Old October 11th, 2018, 17:13   #1
BigTurboAlh
Fuel Economy: 35
Default Cjaa internal strength
As title says. How much whp are people doing with stock bottom end? Iím pretty sure they have fractured cap rods.
2000 ranger alh swap daily driven
dual valve springs, pistons flycut and decompressed, arp rod bolts main studs head studs, h beam rods, pnp, frank06 cam and oil pump, fueled, sb drag clutch, fass 150, hx30-hx40 compound, nx water meth kit, special injectors, 11mm pump, 3.5in downpipe to 4in rest of the way back.
BigTurboAlh is offline   Reply With Quote
Old October 11th, 2018, 17:22   #2
[486]
TDI(s): 02 golf ALH
they do
and some very nice looking pistons
only got a shortblock someone siezed, so no input from me other than that the hard parts look very nice
Old October 11th, 2018, 17:35   #3
BigTurboAlh
Fuel Economy: 35
I figured lol think they would last at 250-280 for a year? I’m trying to avoid tearing into it till steel pistons come out.
Old October 11th, 2018, 18:07   #4
turbobrick240
turbobrick240's Avatar
I don't think that would be a problem. You could always limit the torque to around 375-400 lb-ft to keep cylinder pressures reasonably safe.
Old October 11th, 2018, 19:06   #5
[486]
TDI(s): 02 golf ALH
probably hold up to that with stock head bolts, even
Old October 11th, 2018, 20:03   #6
BigTurboAlh
Fuel Economy: 35
Hmm I was just gonna put studs and springs in it. But I guess I’ll leave it stock till next year.
Old October 11th, 2018, 20:34   #7
turbobrick240
I don't think you'll see 280 whp with the stock valve springs. Probably not even 250 whp.
Old October 12th, 2018, 18:36   #8
travis45
travis45's Avatar
267hp on stock valve springs....
https://youtu.be/sK8rjQRICe4
Colt stage 3 cams, valve springs and head porting next... still on stock head bolts. ARP studs with upcoming head work.
14 Sportwagen GTB2260vklr Turbo, Rawtek turbo back exhaust, Malone custom tune, CP3 Fuel Pump, Malone DSG Tune, Panzer, 19" Konig Oversteer Wheels, Fluidamper Crank Pulley, H&R 22mm rear sway bar, PolarFIS, Darkside intercooler and piping, Wavetrac LSD. Soon to install Colt billet stage 3 cams w/upgraded springs, ARP Headstuds.
travis45 is offline   Reply With Quote
Old October 12th, 2018, 19:09   #9
turbobrick240
That's awesome! Especially on a Mustang dyno. You should post up a pic of the dyno plot. I'd love too see where a 2260 cjaa makes it power.
Old October 12th, 2018, 20:16   #10
travis45
travis45's Avatar
Old October 12th, 2018, 22:16   #11
turbobrick240
That's a beautiful thing. Max power at 4850 rpm! The torque on my cr170 mustang plot starts falling off at 2400, and max power at 3860. Maybe it's time to break the piggy bank and buy a gtb kit.
Old October 13th, 2018, 08:19   #12
travis45
travis45's Avatar
She pulls hard all the way to redline. Could use a little dialing in yet. Will be updating the DSG tune to up clamping pressure and bump the shift points up a bit before trying for more power.
Really excited to get the head in order. So far as I know, I have the first Colt stage 3 cams in existence for CR TDI's.
Hoping to crack 300hp. I think it can be done. Jamie Bridges made 394hp with a stock bottom end.
Old Yesterday, 15:28   #13
BigTurboAlh
Fuel Economy: 35
Sick that’s what I like to see head studs also? Any videos of Jamie’s car?
Old Yesterday, 17:31   #14
travis45
travis45's Avatar
Jamie is XJAY here on the forum and does have some YouTube videos. He also has his big turbo for sale on the classified forum here.
windshield strength lukyluke VW Passat Family (NMS and B7) TDIs (2012+) 9 September 10th, 2015 07:07
Axle strength raider929 Upgrades (non TDI Engine related) 3 August 20th, 2015 02:29
block strength Jakx1331 TDI Power Enhancements 2 October 19th, 2014 14:49
FS - 2010 Jetta TDI CJAA CJAA QuickTD Ontario 3 March 2nd, 2014 06:29
Transmission strength? mlemorie TDI Power Enhancements 0 June 11th, 2011 15:13
Page generated in 0.15017 seconds with 12 queries
[Output: 119.55 Kb. compressed to 99.45 Kb. by saving 20.10 Kb. (16.82%)]
