ItsADiesel
I'm doing a timing belt/water pump job on my TDI in a couple weeks and I figured that while I have all the coolant drained I might as well put in the head studs I have. My question; is it ok to just remove the old head bolts and install the head studs without changing out the head gasket? Or is it necessary to put in a new head gasket when you remove the bolts?
Thanks in advance!
-Fred-
Thanks in advance!
-Fred-
