Old August 3rd, 2013, 17:28   #1
Vegified TDi
Default Harmonic balancer bolts stripped
Hi. Changing a timing belt on a friends 1999. One of the valve cover bolts and all of the harmonic balancer bolt heads are stripped. I have a new and not rounded #6 Allan head socket but to no avail. It seems like the last time it was installed the head slot became stripped. Any ideas on how to get them out? Extractor didn't work.
2006 Jetta TDi on WVO (Waste Vegetable Oil)
2002 Ford Excursion 7.3L Diesel also on WVO
1996 Audi A6 Avant Quattro 2.5L TDi on WVO
1998 Honda VTR1000....not on WVO
Vegified TDi is offline   Reply With Quote
Old August 3rd, 2013, 17:29   #2
greengeeker
greengeeker's Avatar
Fuel Economy: 42.2/50.0/58.1
External easy outs work everytime for me.
- Nick -
02 Jetta TDI 340k (42.2/50.3/59.4 MPG) // 01 Eurovan 24V (18 MPG) // 00 TDI Ranger (39MPG)
How to Post Pics - How to Search
TDIclub trusted mechanic in Minnesota - PM me
greengeeker is offline   Reply With Quote
Old August 3rd, 2013, 17:34   #3
Vegified TDi
The ones you tap in which bites into side of head? Tried that. I have the round style. Didn't work? Thought it was going to snap off before it turned out of the head.
Old August 3rd, 2013, 17:53   #4
PeterV
HO5G Doyen & Zen Master
PeterV's Avatar
At this point .......heat...... I feel sure you would like to have a harsh word with the person that did the last TB..
PeterV 'BUG*pwr award 2005'
'00 Jetta TDI, RC, Shine, DG RPipe, 520PP, DG/SS LED Boost ASR. Home of HO5G ('96 Cummins CTD 3/4 ton now at 274 HP 670 ft Lbs TQ riprust) Ram 1500 hemi
Trusted TDI Mechanics Map || VCDS Locator ||
PeterV is offline   Reply With Quote
Old August 3rd, 2013, 19:37   #5
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Fuel Economy: 116 mpg(e), 36 mpg gas, 100 mpg combined
Try hammering in a triple-square, that's my remedy. The cap screw heads are soft enough to re-form and grip on 12 points better than they did on six flats.
As long as that continues to work, I don't need to spend for a set of external fitting extractors. When the 3-4 also strips, THEN I'll go get a set of extermals.
Svante Arrhenius 1896
Old August 3rd, 2013, 21:21   #6
Genesis
Fuel Economy: 53/48/42
Those bolts are pretty soft and easy to strip, ESPECIALLY if you use an extension on them when installing (or removing); any off-center torque and.... oops.
I've not managed to booger one yet but I pay REAL close attention when wrenching on them as I know exactly what WILL happen if I don't.
Genesis is offline   Reply With Quote
Old August 3rd, 2013, 21:30   #7
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
I drill them out, once the head is off the bolt will usually come right out. Only takes a few minutes with a good bit.Replace with 10.9 flanged hex heads so the next person will not have that issue.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 395K miles and climbing.
09 Jetta Gasser, autofailmatic. Backup car. 230K.
turbocharged798 is offline   Reply With Quote
Old August 3rd, 2013, 21:53   #8
AndyBees
AndyBees's Avatar
I always give them a hard whack using a piece of brass and a hammer before attempting to loosen. I know, this is after the fact.
Also, I have used a cutting punch to break them loose once rounded out.
You have good suggestions in the above posts.
One thing I've noticed is that the torque spec is probably 5 pounds more than is necessary. I've always torqued them 5 pounds below spec with no issues............. they come out much easier too!
This is the TDI Club, a place to share experiences & ideas, ask for help, etc. Welcome Newbies! Sarcastic and condescending posts shouldn't be welcome.
AndyBees is online now   Reply With Quote
Old August 3rd, 2013, 22:00   #9
Metalhead
Metalhead's Avatar
Fuel Economy: 40/44/49
Simple simple. I've never done a TB job and not had at least one strip. Take a 12mm 12 point socket, and hammer it over the head of the bolt. Comes right out.
Don't hold me to 12mm though. Just find a 12 point socket that fits snugly over it, and give it a few taps till it's on the bolt. Then just twist it out. Works every time.
I have a Hex-USB+Can VCDS cable, Metalnerd Rear brake tool, Metalnerd IP triangle tool, and Metalnerd Alternator bit set
Metalhead is offline   Reply With Quote
Old August 4th, 2013, 06:21   #10
poor1
TDI(s): MK4
Fuel Economy: 56mpg (UK gallons)
Don't use an impact driver to get them out either!
poor1 is offline   Reply With Quote
Old August 4th, 2013, 07:12   #11
jasonTDI
jasonTDI's Avatar
Fuel Economy: 13.7 c, 12-15 towing hwy. 17-19
Hit it on harder. Get bigger socket wrench. Twist until it comes free or breaks. What other choice do you have?
Jason, Service work available. www.jasonTDR.com
Give a hand,www.akitas.org
jasonTDI is offline   Reply With Quote
Old August 4th, 2013, 08:12   #12
Fix_Until_Broke
Fix_Until_Broke's Avatar
Fuel Economy: 75.0/53.0/38.4
^^This
If there's any hex left, take your 6mm tool and put it back in the bolt and give it a couple good hard hits with a hammer (like you mean it) and it will spin right out. If there's no hex left, do the same thing and then try a 12 point/triple square, next size larger fractional one, a vicegrips, etc. Once you hit it with a hammer a few times they come out very easily.
I replace them with 12.9 capscrews which are much harder and don't strip out as easily the next time.
03 Jetta, Cat 2u, DG Steel SP w/MOGolf Mod, 3"DP, 4"EXH, EaBP100 Bypass, Euroswitch, ECodes, Driving Light, PD Lift Pump, R520's, RC5,RC6, TDTuning, Malone, ScanGaugeII, 3" TIP, 2" TOP, HE221W Compounded with GTC1444VZ, 6 Bar MAP, VR6 MAF, Vented Fender Liner, Battery Cover Mod, 11mm, Monster Mats, 215/55/17 (27.9/53.0/75) Monthly MPG Links, Euro Trunk Latch, IDParts RSB, SDI or ALH Intake, ARL Ceramic Pistons, Rosten Rods, DRW, Wavetrac, SBC, FSD's, Beef Springs, Rebuilt Head, Recaro's, Colt II, DG Sigma 6, RMT200
Fix_Until_Broke is online now   Reply With Quote
Old August 4th, 2013, 08:18   #13
mr_dink
I've had success with hammering a torx bit into them.
About a t40 iirc.
mr_dink is offline   Reply With Quote
Old August 4th, 2013, 09:51   #14
Lead_Sled
Fuel Economy: 52
Had this happen a few weeks back. I used an external easy out that I had a set of. Removed the 2 bolts that I could. By the time I finished hammering the external easy out over the bolt, it was fairly easy to get out. But maybe my hammering was quite excessive. Nevertheless, they gave way.
99.5 New Jetta 5spd
Best so far - 62 mpg
Lead_Sled is offline   Reply With Quote
Old August 4th, 2013, 19:08   #15
dogdots
dogdots's Avatar
TDI(s): None
I keep 3 craftsman 12 point 12mm sockets in my toolbox for when the hex head rounds out. I usually have 1 round every 3 or 4 timing belt jobs even after tapping my 6mm snap-on with a hammer before using the impact to zap them out. Just pound the 12mm socket on there and it will zap right out.
I keep craftsman 12mm spares so I can trade out the cracked ones at sears at my convenience instead of the convenience of the snap-on dude.
Non VW: 2011 BMW 335D and 2011 BMW X5 35D, 1977 MB 280SL, 1979 Chevy C20 6 banger with 51k original miles, 1977 Chevy C10 454 bought new by wife's grandfather.
www.kansascitytdi.com
dogdots is offline   Reply With Quote
Stripped Harmonic Balancer Bolt, Doh! ahardy4 TDI 101 33 June 8th, 2019 06:56
Stripped bolt remover, harmonic balancer Bob702 VW MKIV-A4 TDIs (VE and PD) 26 March 8th, 2015 18:56
Harmonic balancer - stripped bolts Jettascuba TDI 101 10 October 13th, 2009 11:20
Installing TB stripped harmonic balancer bolt terrydtdi TDI 101 7 July 23rd, 2007 17:25
Stripped Allen head at harmonic balancer rrick VW MKIV-A4 TDIs (VE and PD) 6 February 12th, 2003 21:53
Page generated in 0.21361 seconds with 11 queries
[Output: 131.51 Kb. compressed to 110.05 Kb. by saving 21.46 Kb. (16.32%)]
