Old April 1st, 2018, 16:34   #1
MittensTDI
Fuel Economy: high 30s City, low 50s Highway.
Default Mobil 1 ESP
hey guys and gals!
I had a question - I know at some point I asked about 0W oils but
I came across accidently that the Mobil 1 ESP both 5W-30 and 0W-30 have listings for the Volkswagen 504 00/507 00 spec on it
would I be able to pour in the 0W-30 in a TDI and have it run or would it just burn up b since its thin
thanks!
https://mobiloil.com/en/motor-oils/mobil-1/mobil-1-esp
MittensTDI is offline   Reply With Quote
Old April 1st, 2018, 16:41   #2
pdq import repair
TDI(s): 09 Jetta
Fuel Economy: 38.5
It is just thinner on the cold side of things so it will circulate better on cold startup.
pdq import repair is offline   Reply With Quote
Old April 1st, 2018, 17:25   #3
tikal
Fuel Economy: 37 MPG (~ 45% city)
That's great to hear that Mobil 0W-30 is also VW 504/507 approved. It is a great oil to go head-to-head with the Amsoil European Car Formula 5W-30 Improved ESP!
tikal is offline   Reply With Quote
Old April 1st, 2018, 20:51   #4
MittensTDI
I thought so! I mean I like Amsoil but I trust Mobil Oils more, especially in my VWs
Old April 1st, 2018, 20:53   #5
MittensTDI
I just wasn't sure if it would be okay to use in, say the V6 TDIs
Old April 1st, 2018, 21:34   #6
tikal
That's great too.
Interesting enough, somebody did some digging and found out the supplier of the base oils Amsoil uses: Mobil :-)))
Old April 2nd, 2018, 05:20   #7
Rico567
<snip>
<snip>
This makes no sense. It's a 30 weight oil, as indicated by the number after the hyphen. It is in no sense a "thin" oil. Expressed in a sentence, it would be "A 0W-30 oil is a 30 weight oil that flows like a 0 weight oil."
The web site BITOG (Bob Is The Oil Guy) has some good tutorials on lubricants, in addition to their forums. I specifically recommend "Motor Oil University."
https://www.bobistheoilguy.com/motor-oil-101/
[URL=http://www.fuelly.com/driver/rico567/passat]
"I reject your reality and substitute my own."
- Adam Savage
Rico567 is offline   Reply With Quote
Old April 2nd, 2018, 07:44   #8
MittensTDI
and I get that part.. what I'm saying is - would it be too thin in a diesel engine
Old April 2nd, 2018, 07:45   #9
MittensTDI
That's great too.
hahahaha that's ****ing awesome.
Old April 2nd, 2018, 11:35   #10
tikal
It has a High temperature high shear (HTHS) viscosity of 3.5 which is what you want at a minimum in these types of engines. For Pumpe Dude engines there is a school of thought that you need a higher HTHS, something at a minimum around 3.8.
The fact that this Mobil 1 507 oil had a viscosity index (VI) of 180 is a plus definitively. If you want to get deeper into the pluses and minuses you can try to find out also the NOACK volatility percentage (lower better). I do not think Mobil publishes this value (Amsoil does) but you can go to www.pqiamerica.com or www.oil-club.ru (use Google Translate) to see if you can find it.
Old April 3rd, 2018, 09:08   #11
InfoSec
Fuel Economy: 48-55mpg
Mobil 1 ESP seems to be pretty good stuff. My ML350 uses that... 9 quarts of it per oil change.... pricey oil changes, to say the least.
The Master of InfoSec - Current '03 Jetta GLS TDI: 02M, Wavetrac LSD, Whitbread downpipe and custom IC piping, Race 520's, VNT1756vk, upgraded SMIC, EGR Delete (obviously), Buzzken 2.5" cat-back w/ turndown, Malone Stage 5 custom, PDlift pump, ARP Head Studs, Phase II: head work, bigger turbo, hotter cam, better pistons/rods, new tires...at least the front ones.
InfoSec is offline   Reply With Quote
Old April 4th, 2018, 06:28   #12
jettawreck
jettawreck's Avatar
Mobil often has their rebate program in effect. $12/5 qts up to $24/10 qts. Local fleet store sells it for $6.49 so the rebate brings it down to about $4/qt.
They sell the awesome DelVac 1 ESP 5w-40 (which I much prefer over a 0w) for $25/gallon which gets a $12/gal rebate making it a great buy. It goes in the TDI and the Honda ST1300 motorcycle and has had great UOA from Blackstone labs.
The current rebate form says for purchases 3/1 thru 12/31/18!!
2004 Cadillac SLS (wife's)
Old April 4th, 2018, 08:45   #13
murphyslaw
I use the 0-30 in the winter and the 5-30 in the summer. Thou I'm not sure its worth the flip-flop.
2014 JSW Sunroof/Nav non-DSG
murphyslaw is offline   Reply With Quote
Old April 4th, 2018, 20:56   #14
MittensTDI
9 isn't bad though for that.... it can get pricey, no doubt
Old April 4th, 2018, 20:57   #15
MittensTDI
that's not a bad deal.
what TDI do you that you have?
Mobil 1 esp? franklinstower VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 8 September 2nd, 2018 17:56
Mobil 1 ESP Formula Derrel H Green Fuels & Lubricants 181 December 20th, 2015 07:52
mobil esp 5/30 pipes p Fuels & Lubricants 8 April 1st, 2011 13:46
Mobil 1 ESP 5w-30 or Mobil1 ESP Formula M 5w-40? spyderhead Fuels & Lubricants 8 September 21st, 2009 08:56
Mobil 1 ESP 5-30 Rod Bearing Fuels & Lubricants 1 August 10th, 2008 18:04
Page generated in 0.17279 seconds with 11 queries
[Output: 127.94 Kb. compressed to 107.25 Kb. by saving 20.69 Kb. (16.17%)]
