RECCE-17
- Joined
- Oct 3, 2010
- Location
- Pembroke, Ontario, Canada
- TDI
- current 2011 Jetta,(ret)01' Jetta TDI (ret) 92' Golf Diesel
Good day,
A6 Jetta 2.0. I have been having issues with the car the past couple weeks. Initially I got 2 trouble codes and flashing glow plug light. I reset it and it quickly took it out of limp mode. Didn't think much else.
I drove from Petawawa to Barrie on friday and the codes came back. I was able to reset them on the move with my OBD2 scanner but eventually that stopped resolving the issue and drove all the way back in limp mode. I got a new MAF knowing that the AIT sensor was showing high signal. That didn't fix my issue...now I have a new MAF.
I scanned with VCDS (after installing the new MAF)and this is what I get.
2 Faults Found:
000568 - Manifold Pressure / Boost Sensor (G31)
P0238 - 000 - Signal too High - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 221849 km
Time Indication: 0
Date: 2013.03.25
Time: 19:20:53
Freeze Frame:
RPM: 920 /min
Speed: 0.0 km/h
Voltage: 14.29 V
Pressure: 980.1 mbar
Pressure: 2190.1 mbar
Temperature: 2.7°C
Temperature: 16.2°C
000275 - Intake Air Temp. Sensor (G42)
P0113 - 000 - Signal too High - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 221849 km
Time Indication: 0
Date: 2013.03.25
Time: 19:20:53
Freeze Frame:
RPM: 920 /min
Speed: 0.0 km/h
Temperature: 134.1°C
(no units): 56.1
(no units): 1.50
Temperature: 19.8°C
AIT showing temp of 134 deg sounds like its not the sensor. What should I look for next?
Also the MAF circuit being too high at the same time as the AIT sensor is making me worry its a bigger problem than plug and play sensors...
MAP showing 2190 mbar might be high for idle? what should it be at?
Any help would be great!
Marc
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 221849 km
Time Indication: 0
Date: 2013.03.25
Time: 19:20:53
Freeze Frame:
RPM: 920 /min
Speed: 0.0 km/h
Voltage: 14.29 V
Temperature: 2.7°C
Temperature: 16.2°C
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 221849 km
Time Indication: 0
Date: 2013.03.25
Time: 19:20:53
Freeze Frame:
RPM: 920 /min
Speed: 0.0 km/h
(no units): 56.1
(no units): 1.50
Temperature: 19.8°C
Marc
