ccaissie
- Joined
- Oct 24, 2018
- Location
- Lincoln County, Maine
- TDI
- 2002 Jetta TDI, 99.5 GL Gasser, 1989 jetta diesel n.a.
Buying a 2002 TDI Jetta for cheap. My friend says he has driven this car since the turbo is not working. Drives slow, he says....oh yah! I intend to look it over before deciding if I myself want to drive it home or call AAA to haul it.
I understand that if the turbo blows apart, it will waste the engine...having replaced turbos and heads on Cummins engines before.
What if the turbo is simply seized. This creates a restriction, so power is far less, but may allow me to putt the car home.
Never owned a TDI (had BMW 2.4, Benz SD), so can I take the intake off and look at the hot side of the turbo to determine anything?
Why would I want to drive it home? To check out all other systems...brakes...steering, etc for eval. Is it a restorable driver or partscar?
