Old October 6th, 2018, 11:13   #1
tncrom
Smile Brake and CLUTCH Fluid Flush - DIY
Hello,
2015 Passat TDI SE w/ 6 spd Manual
I'm using a pressurizing method to flush and replace the brake fluid today. I understand the procedure for the brakes as there's great info on youtube and in forums.
My question is about flushing the clutch slave cylinder. Is it located underneath the battery box? Or under the air box? Looks like I will need to remove the airbox to locate I'm thinking.
Or can it be found elsewhere? Guidance appreciated. It's Saturday, so I'm in the midst of this right now -- here I go! Can't wait much longer as weather is getting colder ever week here in Iowa.
Thanks in advance.
Chris
Last edited by tncrom; October 6th, 2018 at 11:14. Reason: Better Title description
tncrom is offline   Reply With Quote
Old October 6th, 2018, 16:44   #2
Swinging Steel
Fuel Economy: 50-NMS, 43-Wagon
I just did it on our 13 wagon. I was surprised to find the bleeder on the slave was plastic and held in with a circlip. I know this is the nms thread, but it might be similar. Did have to take out the air box for access. And it helps even more to have a nice length of tubing. The fitting on the wagon was a 1/4 turn I believe, maybe 1/2. Did it by hand, but you could put a wrench on it.
Swinging Steel is offline   Reply With Quote
Old October 7th, 2018, 14:03   #3
tncrom
Thanks for the info. Meantime yesterday, I kept searching for it and made a couple of pictures that will hopefully help others if they run into this too. There isn't much mention anywhere of a bleeder valve block on the internet. ECS makes an aftermarket bleeder valve block which helped me find the OEM version on the car. It's exactly like you describe, Swinging. Underneath the airbox and with a plastic "nut" / valve. The two pictures show the location of the clutch bleeder valve for the slave cylinder underneath the airbox and the second shows a closer view of the valve itself. Mine has a yellow plastic nut which is shown by the arrow.
https://www.flickr.com/photos/161263...posted-public/
[IMG]https://www.flickr.com/photos/161263043@N06/44442509734/in/date
posted-public/[/IMG]
Old October 7th, 2018, 16:47   #4
Swinging Steel
Yeah, it's pretty cheesy if you ask me... But in reality, how much do you really need to do that job in the first place? It's not like you're ever going to boil the fluid in the clutch.
Old October 10th, 2018, 10:09   #5
740GLE
going to the way back machine, this is from my 2010.
Did fluid flush once at Nov '11, so just over 2 years service, def came out milky white I did have to pull the air box.
Old October 11th, 2018, 10:14   #6
tncrom
Thanks for that additional info. Did the fluid coming out at the brakes also have the milky white appearance or was it only at the clutch bleed location? Thanks again. Chris
Old October 12th, 2018, 04:37   #7
740GLE
i remember the clutch being more milky than the brakes, something like 2-3" of fluid in the tubing on the clutch compared to 1/2" or less and way less milky from the calipers.
Brake fluid flush fire32njetta Eastern USA 1 March 15th, 2016 17:27
Brake Fluid Flush 2002MK4 VW MKIV-A4 TDIs (VE and PD) 11 April 17th, 2012 06:52
DIY Brake Fluid Flush theedudenator VW MKV-A5 Golf/Jettas 8 February 10th, 2012 05:37
looking for a DIY on manual transmission fluid flush kilimats VW MKIV-A4 TDIs (VE and PD) 13 July 23rd, 2007 19:19
Four Wheel Brake Job and Brake Fluid Flush Outline flash9 VW MKIV-A4 TDIs (VE and PD) 9 November 1st, 2006 12:02
Page generated in 0.13933 seconds with 11 queries
[Output: 79.76 Kb. compressed to 69.34 Kb. by saving 10.42 Kb. (13.06%)]
