timeline
I have a TDI 2002 waggon which the ABS light and code says bad cable or disconnect. Can a bad speed sensor be to blame for this code or is it usually the cable breaking due to flex. What resistance would i measure across the plug at the wheel end to confirm cable is ok? If open, would this confirm a cable break?
I ordered a cable and it was not the original part. the new one had plastic stops which would not feed through the side wall where the other cable went. Is there a part number for my car someone could give? No Manual.
A bit bewildered. Thanks for any help.
Gary
Gary
