moondawg
CAT's CRS (Caterpillar Regeneration System) is a "burner" that sits at the outlet of the low-pressure turbo. It has: A fresh air connection, a compressed air connection, 2 coolant connections, a diesel fuel connection, and a spark plug. It attemps to light a flame, keep it lit under varying engine conditions, and use that flame to provide heat to burn soot in the filter.darkscout said:That's what every on high way truck manufacturer is doing (that I've seen). Cummins and DDC are using dosing, Caterpillar is using their own "CRS" system to elevate exhaust temps.
Is there a scheduled ash removal period? Burned oil creates ash. The ash doesn't burn off in the DPF and accumulates, which means that after time it has to be removed.
It's a nightmare to say the least.
I'm skeptical, to say the least. You are correct about Cummins, DDC, and Volvo, they all use a doser/DOC/DPF arrangement. In fact, they all use a Cummins Filtration filter. Volvo uses the Cummins turbo, as well.
Ash removal is on a ~400,000 mile time-table, depending on duty-cycle.
moondawg
