Hi all, I'm a new member, any advice would be much appreciated. I recently took my 2010 Jetta TDI with 40,000 miles to the dealer to get a fuel filter replaced.
A couple days after I had the service done I took a 150 mile trip to visit my in-laws. I noticed a big puddle accumulate underneath my car's front end after letting it sit for a couple hours. I opened the hood and found that half of my engine bay was covered in diesel fuel. I walked around my car and noticed that I had a lot of greasy black soot covering my rear end and the passenger side of my car that was not present prior to the trip. I did not set off any sensors during the trip.
I tried to find the cause of the leak and discovered that my fuel filter housing was dripping diesel from the top when I idled my car. I opened up the fuel filter housing and I saw that the top black o-ring was frayed and not making a good seal causing the leak. I left my car parked and drove my in-laws car to a nearby VW dealership and bought a whole new fuel filter kit and replaced the broken o-ring. I idled the car a little bit to make sure the leak was fixed and then tried to drive back home to the VW dealer that serviced my vehicle to get them to look at the fuel filter problem.
After driving about 30 minutes with the new o-ring installed the car shudders, stalls, and I end up having to call a tow truck to get it the rest of the way to the original dealership. The dealership said that my serpentine belt failed and it will need to be replaced which would be covered under warranty.
This has been a trouble free car for the past 40K miles and I am in disbelief how I could have a serpentine belt failure this early on.
Is it possible that my serpentine belt failed because of fuel spraying inside of my engine bay or was this just a coincidence?
Should I worry about anything failing inside my engine bay that's in close proximity to the fuel filter?
What are potential implications for the hpfp?
What kind of recourse should I seek from the dealership that changed the fuel filter?
Thanks for the help.
