whitehatch
UPDATED 11/29: Beetle headlights have been sold
I think I have finally pulled everything off of my car to sell so take a look! Feel free to let me know if my prices are wack. Shipping is not included in any of these prices and there is no way I will ship the seats or bumper.
Random car alarm with everything except the siren - $15
Clear lamin-x covers for New Beetle fogs and front turn signals - $SOLD
Random parts from the ex-gfs beetle, I don't think she will miss them
Driver side reverse light - $SOLD
Shifter parts - $SOLD
Antenna - $SOLD
Headlights - $SOLD
Rieger RS4 look Mk4 Golf front bumper painted black with standard rock chips. Includes additional mounting brackets, the mesh for the passenger opening and a grommet in case you want to be able to use your tow hook - $SOLD
Complete black 04+ style center console, requires you to modify your e-brake handle - $SOLD
WRD adjustable end links with all hardware - $SOLD
Filled Mk4 Golf black hood also with standard rock chips. Top quality work with a metal notch filler - $NLA
Complete set of early illuminated Jetta vents in great shape with harness and mounting brackets - $SOLD
Early Passat d-pad style mirror switch with harness - $SOLD
Complete Euro R32 DSG airbox with big intake pipe and the plate that goes behind the headlight. This has been configured for use with a TDI so it has a nipple for the small vacuum hose that attaches to the airbox and a custom adapter that allows the stock MAF to fit - $SOLD
ALH TDI timing belt tools. Cam sprocket puller, cam sprocket counterhold tool and crank lock are metalnerd. Cam locking plate and tensioner tool are from Impex and pump pin is a pin gauge. - $SOLD
Funk switch - $SOLD
ASR switch - $SOLD
Airbox mounted filterminder (25 inches water) - $10
Dash mounted filterminder (25 inches water) - $10
Leaky EGR valve (oil leaks from weep holes). Would be useful for a stealth race pipe - $SOLD
Stock MK4 TDI Golf suspension with ~59k miles - $NLA
Stock MK4 Golf grille - $NLA
Ball seat wheel to cone seat bolt adapters (set of 20) - $SOLD
Passenger side outer front seat trim from a 4 door MK4 Golf - $NLA
Rear mudflaps from a MK4 Golf (no hardware) - $NLA
Coolant manifold and hose from a 2000 auto ALH - $SOLD
Pair of H7 high beam bulbs - $SOLD
Antenna - $SOLD
Headlights - $SOLD
Funk switch - $SOLD
ASR switch - $SOLD
