Old April 16th, 2018, 16:12   #1
BigTurboAlh
Fuel Economy: 35
Default 4 bar map sensor calibration
I canít get this linerization right to save my life. Iím using a dark side 4 bar part #03K906051. Shows 10psi absolute instead of 14.7psi. Also it builds 22psi and Iím asking for 35psi. tune is a agr wastegated file. 10psi spring.
Tried
93----200
896----3408
44=200
913=4000
2000 ranger alh swap daily driven
dual valve springs, pistons flycut and decompressed, arp rod bolts main studs head studs, h beam rods, pnp, frank06 cam and oil pump, fueled, sb drag clutch, fass 150, hx30-hx40 compound, nx water meth kit, special injectors, 11mm pump, 3.5in downpipe to 4in rest of the way back.
BigTurboAlh is offline   Reply With Quote
Old April 17th, 2018, 01:39   #2
bhodgkiss
I have a 4 bar map sensor running fine.
Its a 0-5V sensor with a 4 bar range, so your cal just looks wrong.
I can dig mine out, but it should be something like 400mV-4800mV giving 200mbar - 4100mbar?
AFN Wagon | Fjord Blue | BV43 | 11mm IP | R520 | PD Lift Pump | Ported head | 3bar MAP | SRE Clutch | FHN G'box | Forge FMIC | PD130 intake | EGR delete | Decat | Custom Remap | Porsche 4-pot 312mm Brakes | KW V1 | Carbon Upper Strut Brace, RS4 Lower | H&R 32mm Front ARB | Whiteline Rear ARB | OZ Ultraleg 18" Satin Black | OEM Xenons | Bucket seats | Battery & washer bottle in boot | 100kg removed |
bhodgkiss is offline   Reply With Quote
Old April 17th, 2018, 06:39   #3
BigTurboAlh
Fuel Economy: 35
Okay let me know Thanks
5 bar map sensor papi123 TDI Power Enhancements 9 October 10th, 2017 09:16
Using 3 bar map sensor on 2.5 bar map car devonutopia TDI Power Enhancements 36 October 5th, 2016 09:17
Bosch 4 bar MAP sensor - calibration? bhodgkiss TDI Power Enhancements 4 September 24th, 2015 18:29
3 bar, 2.5 bar map sensor, thermo switch blitzed Private TDI Items for Sale/Wanted 6 March 29th, 2014 14:09
2.5 or 3 bar map sensor? Link977 TDI Power Enhancements 3 March 2nd, 2008 14:42
Page generated in 0.11689 seconds with 13 queries
[Output: 58.07 Kb. compressed to 52.72 Kb. by saving 5.36 Kb. (9.22%)]
