TDIRugger
2003 Jetta GL TDI… which would be an ALH correct? 5 speed with 150K
Ok so I dropped off my car at a Firestone Auto Center to get an oil change, tire rotation, state inspection, brake rotors and look at the turbo (the MIL light was on). Car drove in there and kind of low power. They changed the oil and when doing so, saw what looked like to be brass flakes. They also hooked up the vacuum lines to the turbo and tested it down the street when the turbo wound up as usual and then blew. When they put it back on the back oil in then engine compartment and then they checked the oil level and it was high. They drained the oil and it appeared to be more watery. Their assumption was that when the turbo blew and oil and coolant all mixed together.
When they drained the oil something came from the pan, they believe that it is some gasket or O-Ring, but not sure because it is in a few pieces. They feel that they no longer want to work on it as they now feel in over their heads and recommended to take it to the dealer.
The dealer wants to check it out on Monday and open up the engine to make sure that the engine is not damaged and it was only the turbo. The dealer wants to charge me $2,488 ($1,683 for parts: Turbo ($1,450), gaskets, glow plugs (needed anyway) and turbo feed line, + $85 taxes + $720 labor). I found with Bora Parts a Borg-Warner for $850.
My questions are:
Has anyone seen this happen?
Does it sound like the dealer is taking me to the cleaners aside from the turbo?
Any help or experience in this matter is very much appreciated!
Brooks
My questions are:
Brooks
