NextExit
For sale is the 2002 Jetta TDI that I bought from NHGranite in 2015.
See http://forums.tdiclub.com/showthread.php?t=447002
There have been some repairs and changes made since. The engine threw a rod last July. Keith Harley swapped in an engine, moving over the injectors and all parts outside of the long block. Any change in power is imperceptible and fuel economy is unchanged (low to mid 50's).
A unique combination of performance and economy.
252 K miles on the body. Engine mileage TBD.
Asking $4100
Engine Mods
Rocketchip RC4+ ASV tune
VNT 17/22 Turbo
PP520 nozzles, recalibrated July 2019
11mm pump
2.5" Matt Whitbread downpipe
2.5" SS full exhaust with turn-down tip
Oversized catalytic converter.
1 aeroturbine muffler
PD150 Turbo Intake Pipe (TIP)
PD150 intake manifold
Darkside race pipe
R32 airbox & snorkel
Tyrolsport SMIC
IDparts upper & lower charge pipes
PD130 oil cooler
PD lift pump
Alum "old Navy" breather w/ BMW cyclonic breather mod
Amsoil 2-micron bypass 2nd oil filter
5-speed Transmission Mods
Wavetrac diff
3.16 R&P final drive
5th gear oil mod
Southbend Stage 2 Endurance clutch
Raxels
108mm flanges
Suspension Mods
Shine 225/180 springs
Billstein HD struts & shocks
Shine Rear sway bar
New front bearings
Audi TT cast lower control arms
Audi TT Spindles & front wheel bearings
Front sway bar removed
Wheels
Summer: 16x7 alloy w/ worn Michelin Pilot Sports, 225/50R16
Winter: 15x6.5 alloy w/ 75% tread Nokians, 195/65R15
Brakes
288mm (11.3") front rotors
1.8T calipers
Upgraded OEM hand brake cable
Supporting Mods
Frost heater w/ lower grill jack
McNally boost/EGT gauge w/ new sender, positioned to prevent oil contamination.
New vacuum pump
Alum DG skid plate
"Big Three" battery and ground cables
Euro light switch
Rear fog light
Euro rear tail lights
FK FS4013 projector headlights w/ projector fog lights. OSRAM DIADEM turn signal bulbs. Yellow H7 fog bulbs.
5-brake light mod
*Bright* LED lighting in trunk
Fuel tank vent mod
GTI Recaro seats
R32 three-spoke steering wheel
"shaved" hood emblem
PD rear trunk
Stereo
Pioneer DEH 80-PRS "active" headunit, with manual
Focal V30 component set (3/4" & 6.5")
Arc Audio 10D4 sub in custom fiberglass sealed corner box
Arc Audio 4ch & Mono amps mounted on custom amp rack
Needs
New summer tires.
Front door woofers need rewiring. Putting down the windows pulls the wires off the woofers.
Subwoofer has gone silent, undiagnosed.
New hands-free telephone mic needs installing.
Driver's inside door handle can be pulled up but snaps back down. I have the needed replacement bracket, but haven't taken off the door card to replace it.
Photos
http://pics.tdiclub.com/showgallery.php?cat=7185
Asking $4100
Engine Mods
VNT 17/22 Turbo
11mm pump
Darkside race pipe
Tyrolsport SMIC
PD130 oil cooler
PD lift pump
Wavetrac diff
5th gear oil mod
Raxels
108mm flanges
Suspension Mods
Shine Rear sway bar
New front bearings
Wheels
Brakes
1.8T calipers
Supporting Mods
New vacuum pump
Alum DG skid plate
Euro light switch
Rear fog light
5-brake light mod
Fuel tank vent mod
GTI Recaro seats
PD rear trunk
Stereo
Needs
New summer tires.
Photos
