Alh and ahu same dimensions?
jhax
Golden, CO
96 Passat B4V, ALH engine out of a 2002 Jetta, some IE Rods and ASV Pistons. Nothing drivable yet though
I want to build a wood engine cradle so I can bench test my motor. I have the dimensions of the ahu block but can't find an alh diagram. Are the blocks the same?
Cheers
Mongler98
COLORADO (SE of Denver)
for what you need, yea basically. just build one that holds it by the pan flange. i posted some pictures before about this
oilhammer
outside St Louis, MO
They are different, they share virtually no parts, and the oil pan is completely different. They do use the same bell house bolt pattern on the block portion, but not the bottom (the ALH is a "full circle" setup, so it has a cast pan that has three of its own bell house bolts).
The overall physical size is not much different, as they are both 88mm bore spaced engines. But that is about the end of the similarity.
jhax
Golden, CO
I apologize for not being not dimensionally specific. Do both blocks have the same horizontal protrusions at the bottom corners?
Bob, thanks for the link, I'm looking to make a cradle so I can put the engine and trans together.
oilhammer
It might help if you can show a picture of what potrusions you are talking about.
Like I said, the AHU and ALH are not the same block. They are not the same family of engines. They do not even mount the same. However, given the variety of applications of both early and late types of engines, they do share some things like the ALH will have threaded holes in the sides that coincide with the mount brackets the AHU has, even though they are not used.
I have an AEG (1998-early 2001 A4 platform 2.0L gas engine) on my bench here that is the same family as the ALH, I would be glad to post a pic for you if that helps.
Mongler98
i stand by what i said, if you build something like this.
$10 at lowes. assuming you have tools to make it.
oilhammer
G60ING
MD
No TDIs Currently, I have an R36 Corrado. I've had an ALH Corrado swap, AHU Corrado swap and 2003 TDI Jetta
Vince Waldon
Edmonton AB Canada
Yup, sitting on something so it won't fall over will be quite different design considerations than running it...running it will require bolting on the transmission (or some part of the bell housing at least) and it will want to twist out of its mounts as it spins up and down.
Sent from my Nexus 7 using Tapatalk
jhax
Golden, CO
My plan is to attach it to the transmission and starter, I have seen videos on here of folks just setting the engine/trans combo on a stack of tires or hanging it from a hoist and starting it up just to make sure it idles at least before I put it into the car. Maybe it's a dumb idea? I just dont want to have a non-running vehicle for too long while I am in the process of swapping the new motor in. Mongler, that is what I am attempting. Hence the original question. But if I cant safely mount it to a cradle like that without it falling off then it's not worth building.
BobnOH
not-a-mechanic
central Ohio
New Beetle 2003 manual
So what you need is for someone to measure the center to center distance of the oil pan bolt edges for both engines. If you're handy with tools and you got the wood and stuff lying around just pop it out with hoist and design/build one.
jhax
Golden, CO
The former and the latter sir ^
CoolAirVw
Kansas City Missouri
Jetta
I started v8's on the floor with less support than that "back in the day".
They were carburated. Because of wiring and since you have to mount a trans to it anyway, it would probably be easier to mount it with just the mounts in the car and start it. Especially if you removed the front end to do the engine.
jhax
Golden, CO
Yeah thats what I think Im going to just end up doing
Mongler98
engine sitting on a tire, 2 if you have them, started a few that way, on the ground on the grass/ dirt, on a slight hill!
my dad has done that a few times, one was a detroit diesel, big mofo, didnt even flinch when started, then again its pan was an inch into the dirt lol
