Hey so I recently purchased a 05 Passat tdi that wasn't building boost p0299. Following all the info I could find on the forums, ( smoke testing the intake, swapping the N75 with a known good one, data logging with VCDS, cleaning the whole EGR system, actuator works as it should, holding vacuum and moving how it should.) I had no ideas left.
I pulled the turbo ( which has little to no shaft play especially for one with 103,000 miles. I noticed that when you spin it by hand it would sometimes "catch".
Upon further inspection and disassembly I noticed it was contacting on the hot side between the wheel and heat shield/backing plate. Not metal to metal, but carbon deposits to the point it was actually slowing the turbo down to a stop. The entire vane system and ring was slightly dirty but nothing that required cleaning. (Did so anyway)
I have cleaned and reassembled and am going to reinstall in the car (waiting on parts). It seems to spin freely with no shaft play still.
Has anyone experienced this before?
