Fiat500Baja
So I have a Jazz 22 gal fuel cell in my baja...what kind of fuel pump and pressure will I need to use?...I was planning to still use the factory type filter that sits next to the timing cover. ..also I wanted to incorporate some sort of g-surge fuel pump to eliminate fuel starvation when driving at extreme angles. ..the pump I'm looking at supplies 340L/PH...is this pump too much for a ALH?...I just don't know what pressure stock fuel pump runs at.
