jokila
That's what my son called my car since I would put her back together again and again.
Last week I was driving about 85 mph down I-10 and started to hear some noises from the engine and felt odd vibrations enough to feel it in the steering wheel and shifter so I pulled over. Check the oil level while it was low on the mark, it was showing sufficient. The engine was not overheated, at least it did not show up on the gauge although i had been dealing with a recent small leak that had me add coolant every 3 days. Had it towed back home to deal with it.
Since it was almost time for a timing belt service I went ahead to opt to replace the oil pump chain which required me to drop the pan and give me a reason to inspect further. Drained the oil and it looked fine. Took off the oil pan and found lots of metal fragments. Found the #4 rod bearing hand spun and was almost completely worn away. The crank journal looks overheated and has wear.
The bearings have about 200K miles using Rotella T6. They were replaced in 2011 when I had the engine partially disassembled due to a valve that ended up cavitating on the lip causing a loss of compression. At the time I didnt know why the engine was running so badly and with the advice here pointing to bad rings,etc. I ended up pulling the pistons and doing a bottom end rebuild.
The engine is at 418K miles now. I am not sure why the bearing spun as usually no oil or overheating can cause it. I found a 2001 ALH engnie with 257K miles and parts car for $600, but there is a part of me that is ready to move on.
Any ideas why you think the bearing gave up the ghost?
