unorganizedplan
damn! he had some great info/experience in his posts, at least on this thread anyway!
I am a madman lol....Actually I guess a crackhead too.He must have been thoroughly insulted when another member called him out on the "Heat" thread under this category. Among other comments he was called a "madman". After that it got worse.
http://forums.tdiclub.com/showthread.php?p=4670373#post4670373
The Moderators should have caught it but the post is still there including both his and the "offender's" post.
we're glad to see you back here! are you using the Bilstein HD for a sportwagen? Is the length of the rears compatible with the lift provided from the springs? did the HD set raise the care a hair?I have Bilstein HD's all around and Stock front springs. I have air bags in rear, but lol I don't need them. I filled the back with firewood and towed a quad/trailer and the only reason I knew was I could chirp in 3rd pretty easy, trying to get away from trailer. I did have 10psi in bags, but they go to 50psi, I just like some air, keeps bags from rubbing.
Ride is significantly better. A bit stiff when empty, but I prefer stiff over soft(that's what she said). I takes turns much better as well, less body roll, plus both front and rear sway bars upgraded.
To be honest, it barely sank with wood/trailer. Didn't measure, but it was still higher in the back lol. I think just new front springs would work for me. I think they are kind of saggy and just done. I drive it hard.
Yes they were from ID parts...I don't have to even think about scraping now, with or without weight/trailer.
I'll have to see the price but on paper this could be everything I've ever wanted, minus DSG only option but I'll let that slide considering it's still not a CVT.Good to see someone at VW was paying attention to this thread.
2016 Golf Alltrack
Now hopefully, we can lift this sucker, too!!!
BTW, from what I'm seeing, it only comes in DSG But the all wheel drive, TDI, and lift over stock SportWagen just might be enough for me to trade my '12 in...
Yes, my "everything" list is:I'll have to see the price but on paper this could be everything I've ever wanted, minus DSG only option but I'll let that slide considering it's still not a CVT.
Thanks, unorganizedplan, for posting up pics and confirming fitment details. That fitment looks awesome! The lift should eliminate the entrance/exit rubbing, and little more offset should take care of the full lock rubbing. Can't wait to be there.
Wow 27" Nice! I ran 215/55/17 for awhile which was 26.3" with the Tiguan Front / Towing Spring Rear combo on Bilstein HD's. I liked the look and it gave me approx 1.5" (3-3.5cm on either side of the tire to the bottom of the wheel fenders all around.2011 JSW
I'm running 215/65r16 blizzaks on a completely stock car.
That is a 27" tire, which gives 1" of ground clearance.
What Tiggy springs net the equal lift to the IDparts Towing rear springs?I ran 215/55/17 for awhile which was 26.3" with the Tiguan Front / Towing Spring Rear combo on Bilstein HD's.
__________________________Strength____Length
Sportwagen Rear:---------------149 lb-in----357mm
Sportwagen Rear HD:-----------194 lb-in----323mm
Tiguan 4motion Rear:----------183 lb-in----363mm
Tiguan 4motion Rear HD:------234 lb-in----340mm
Sportwagen TDI Front:---------144.5 lb-in---345mm
Tiguan 4motion TFSI Front:----184 lb-in----359mm
Approximately 16 1/2" to 16 5/8" for the front from center of the wheel to the top of the arch. The rear is 17"Thanks, schreibers, it's nice to see more details specs with different setups. That sounds pretty sweet.
Would you mind posting measurements from the center of the wheel to the wheel arch? That will eliminate any tire variables from the lift figures and give widely comparable numbers.
