Old February 2nd, 2004, 06:20   #1
Radman
Default Vag-Com Issues, Help?
I should have posted here in the first place, sorry!
http://forums.tdiclub.com/showflat.php?C...o=7&fpart=1
Radman is offline   Reply With Quote
Old February 2nd, 2004, 06:32   #2
penclnck
Do these cars have power windows? If not, then there won't be any CCM to scan in the first place, you would want to go into address 35 for "Cent. Locks" on cars with manual crank windows.
penclnck is offline   Reply With Quote
Old February 2nd, 2004, 06:45   #3
Radman
One has P/W and one does not.
My problem is I cant get in at all. Its not identifying the vehicle. (Only in that Module)
Old February 2nd, 2004, 07:22   #4
VelvetFoot
VelvetFoot's Avatar
You can't get into the convenience module at all? Is it an interface made by ross-tech?
edit: But if you can get into other modules you would think it could get into this one.
VelvetFoot is offline   Reply With Quote
Old February 2nd, 2004, 08:06   #5
Radman
Yes it is a registerd Ross-Tech interface and I can get into other modules. Maybe a software problem?
Old February 2nd, 2004, 08:45   #6
jaydhall
Whenever I could not get into other modules, it turned out I needed to look at the flaky communications PDF at ross tech and follow it. My laptop does not like too many things running on it with some controllers. YMMV
jaydhall is offline   Reply With Quote
Old February 2nd, 2004, 21:51   #7
Uwe
Uwe's Avatar
If you cannot get into 46 on a car that has power windows, try re-booting the whole car. 46 has the nasty habbit of going deaf/dumb on these cars on occasion. Disconnect both cables from the batter. Short the cables together for 10 seconds. Reconnect them to the battery.
-Uwe-
Uwe is offline   Reply With Quote
Page generated in 0.12029 seconds with 10 queries
[Output: 71.75 Kb. compressed to 61.71 Kb. by saving 10.04 Kb. (14.00%)]
