Andyinchville1
Hi All,
With the weather getting even colder , I was wondering how hard can you push a "cold" engine without damaging it?
FWIW- these are the rules I typically set for myself for driving a cold engine ...
I typically start the engine and let It run about 30 seconds ( time passes quickly here since I am putting on seatbelts, setting radio station , organizing the car etc...)
I drive easy in lower gears until the engine gets to about 160 degrees before even using 5th ( the owners manual for my 1993 w250 pick up with Cummins diesel I think recommended that practice ( not using overdrive until stuff warmed up) so I carried it over here.... rpms are typically under 2000 rpm .
If it is really cold out I admit I do still put the heat to max but I do leave the fan speed at 1 so as not to take too much heat from the engine until it warms up...
I try to limit boost to 4 psi or under so as not to stress the engine unduly when cold.
At what temperature can you start pushing the engine harder? ( is there a chart of sorts showing max recommended engine output ( as a function of boost or other measurable parameter) vs engine temp?
In summary .... how hard can you push a cold engine before causing undue wear and damage?
Andrew
Ps - yesterday I stopped at a rest area to sleep for about 3 hours ... when I woke up and started driving again the ScanGauge indicated a water temperature of 100 degrees... I drove on the highway at 45 to 50 mph (speed limit 70) until the engine reached a temp of 175 before picking up the pace... needless to say there were some unhappy campers passing me .... I did have 4 ways on ... I figured I'm not going to jeopardize the car by over stressing it when cold ....
Andrew
