bprince
hi all,
I have a 05 jetta wagon BEW engine and I have an oil leak on the back side of the engine. It seems to be leaking quite a bit, and its been leaking for quite some time (~1 year). I've only looked at it from the bottom so far. My biggest concern is that it leaks on the exhaust manifold and it really stinks (can't handle the smell any more). In the winter it doesn't smell, it only seams to smell when there is low cabin pressure. I thought it was exhaust so I changed the pipes out of the muffler to straight pipes past the bumper. Didn't help.
Any way last weekend I removed the valve cover, checked the seal (looked good, no visible signs of leaking), cleaned and put it back on. No change in the leaking.
So what I've read the intake manifold could be the culprit. My question is. Is it normal for that much oil to be in the intake manifold? It seems like quite a bit. Will replacing the gasket solve my problem?
Thanks for listening to my rambling. This VW could be the last with all the problems it's had. The first three were stellar.
