ymz said:
Thanks... now... do I want the G005000 or the G052726A2 ????? (the latter's cheaper than the former, as you know...)
Yuri. (Still confused... but that's not unusual...)
Here's the latest from post 173 with the VW fluids in
green:
(Manual Tranny Fluids) (Sorted by viscosity at 100C)
VI Vis@40C Vis@100C
128 159.0 18.3 = AMSOIL CTL SAE 50 Powershift
GL-1
..............16.7 = Motul MOTYLGEAR 75-90
GL-4/-5
..............15.6 = VW G005000/G005100 GL-4
185 90.0 15.6 = Redline MT-90 75-90 GL-4
..............15.2 = Mobil 1 Synthetic 75W-90 GL-5
..............15.2 = Motul Gear 300 75-90 GL-4/-5
..............15.0 = Elf Tranself Synthese FE 75-90 GL-4/-5
132 116.0 14.9 = AMSOIL AGL 80W-90 GL-5
177 84.5 14.7 = AMSOIL MTG 75-90 GL-4
133 76.2 11.0 = AMSOIL CTJ SAE 30 Powershift GL-1
183 56.2 10.6 = Redline MTL 70-80 GL-4
194 47.1 9.6 = AMSOIL MTF Synchromesh Trans fluid (GM/Chrysler) None
208 41.6 9.08 = Penzoil Synchromesh trans fluid None
198 34.0 7.5 = Redline D4 ATF Dexron III / Mercon / API GL-4
138 40.5 7.1 = AMSOIL CTG SAE 10W Powershift GL-1
..... 31.2 6.5 = VW G-052-171-A2 None
..... 35.1 6.38 = VW G-055-726-A2 None
..............6.3 = VW G52 (part numbers G052726A2 / G05272601) None
The synthetics will perform much better for you in the winter (I'm originally from Nrn Michigan - Lake Superior's South shore - so can relate to anyone using petroleum gear lube in the winter - can you say 'two handed shifts'?!) I wouldn't recommend a petroleum gear lube in cold country - for both shifting and fuel mileage.
The original G50 is 'heavier' than the latest G052726A2 (at the bottom of the list). The G52 will give very easy winter shifting and the best fuel mileage. We don't know for sure what it's GL rating is - the bottles aren't labeled with anything but a part number - but VW shouldn't spec a fluid that doesn't meet minimum warranty requirements at least.
Closer to the original G50 you'll see Redline MT90, then AMSOIL, then Redline MTL. Folks in hotter climates have said that MT-90 feels like the OEM fluid but can be stiff in the winter. Folks in cooler climates prefer the smooth cold shifting of the MTL. Hopefully that gives you a 'feel' for the viscosity difference.
I'm using the reallllly thin G52 right now - mainly as a fuel mileage test. Shifting is very light (of course, I'm in San Antonio). I have an old transmission (342,000 miles) and a dieselgeek short shift kit and I have to remember to slow my shifts from 1st to 2nd to keep the synchros from grinding - it shifts very, very easily/quickly/smoothly - even out of gear. There's almost none of the 'feedback' you'd get from pushing thru heavier gear lube.
'Bang for the Buck'...
I paid about $34 per liter for the G052726 at the dealer. If you can get it
cheaper than the original G50 then go for it! You can get about 4 quarts of AMSOIL for the price of one G052. Either Redline product should be less expensive as well. The G052 might pay for itself over time in fuel savings and should be the absolute best in winter performance.
I hope that helps a bit Yuri.
Andy
edit: spelling. What's a 'cleaper', anyway?
