Bcohen
Had some vacuum leaks from visibly cut vacuum hoses. Id get limp mode pretty regularly at highway speeds but normally only if i pushed it or was going up an incline. Turbo actuator was recently changed. so I had the mechanic swap out all the vacuum lines for new. hopefully fix the problem right? Nope. Now I have zero power, limp mode from the get-go. Havent had a chance to scan it yet but did inspect the vacuum hoses and they appear to be in correct order. (Oh, the nipple broke on the anti shudder solenoid but thats been like that for a while) Also, new CCV and elbow were installed with vacuum hoses.
Any ideas what the hell is going on??
