jdulle
I am going to change the supply fuel line check valve on my 96 B4. Do I need any special tools to get the old one off? A couple of pliers for keeping fuel from draining out from either direction?
Wait what? Are you saying that they don't work? Cant you make or get a spring loaded check valve? I use them on my water meth injection to prevent back flow and to break the siphon effect when its not on.There is no way to prevent the fuel from draining back into the tank, so just prime the IP when you're done.
As soon as you remove the supply check valve, the fuel in that line between the check valve and the tank is going to drain back into the tank. It's simple physics.Wait what? Are you saying that they don't work? Cant you make or get a spring loaded check valve? I use them on my water meth injection to prevent back flow and to break the siphon effect when its not on.
He was talking about what happens after you've removed the one-way valve from the line for replacement, the fuel will want to move back in the direction of the tank.I was confused. If you take the hose off to take the check valve off and replace it, it would not drain back into the tank, but rather into what ever catch basin you have to catch all that fuel siphoning back from the filter and the entire line. When you said " back into the tank" i got confused. Not sure hot taking a hose off puts it back into the tank without reconnecting it. Sorry, i see what your saying but it did not make logical sense the way you said that bit. Also it was so simple and obvious that i read into it too much.
