Bought the car a month ago at 286,000, now at 287,000. It has been a productive month - I have performed the following work:
- sanded/polished headlights
- installed Kbrenny painted Avus wheels, new tires
- cleaned intercooler and piping
- eliminated CCV heater, EGR, cooler
- cleaned intake manifold
- installed dieselgeek timing belt set
- installed boraparts eurospect/sachs G60 14#/VR6
- replaced rear main seal
- replaced front main seal and housing, oil pump drive chain, tensioner
- replaced leaking oil pan with OEM hybrid
- replaced thermostat and housing
- replaced brake/clutch fluid, green coolant with red, motor oil, manual trans fluid
- replaced fan control module, recharged A/C
- replaced taillight bulb holder, driver door latch, trunk latch, fuel door latch pin
- eliminated rear wiper, relocated washer bottle to rear
- replaced carpet, door sills
- rebuilt seatbelt receptacle
- repaired (rigged) RH seat back
- rebuilt LCAs with TT bushings
- installed Bilstein Sport struts, new OE mounts and bearings
