Grave Robber
prior post here: http://forums.tdiclub.com/showthread.php?t=477720
tl;dr: sudden loss of power getting on the freeway, diagnosed as probable turbo failure. got home and had tons of oil in the intercooler piping. replaced turbo and all vacuum lines, the main shaft had tons of end play and there was oil all over the outside casing of the turbo. Issue persisted. replaced EGR valve, still no fix.
On to the present!
I am still getting the p1556 error code and having jumpy acceleration even after replacing the most likely culprits. I even went ahead and replaced the N75 valve with no change (the one on the driver side). I can bypass the N75 valve altogether (and I think most of the vacuum components) and it runs just fine, a bit down on power, but without the jerky acceleration. After I kill the engine I can pull the vacuum line off the reservoir bulb and I can hear the hiss of vacuum being released, so I don't think the pump is at fault.
I have a vacuum pump available but I'm not sure how to check all the lines for leaks (which is another possibility)
What do you guys think?
Also, could it be the other N75-esque valve near the middle of the firewall (under the windshield wiper cowling)?
edit: please be as descriptive as possible, this is my first turbo diesel and Volkswagen. Put it into Mustang terms if possible (we are a simple bunch)
On to the present!
