Hey folks,
I'm hoping I didn't screw this up - First time doing a clutch. Installing the Luk LFW134 flywheel I looked all over for the correct torque specs on the flywheel bolt and it seemed like the most reliable info was 1st stage: 22 ft/lbs, 2nd stage: 44 ft/lbs, and then final stage: a 1/4 turn...I did all this so ended up at 44 ft/lbs plus that last quarter turn which had me nervous as hell they would snap it felt like so much resistance at that point.
Now I'm wondering, did I misinterpret the directions? Were those instructions for 2 different types of flywheels? Single and Dual mass? I certainly hope not.
I arrived at this conclusion because pressure plate bolts seem to have different specs depending on whether it's single or dual, 10 ft/lbs and 15 ft/lbs.
If I should have stayed at 22 ft/lbs can I safely back the bolts out a bit now that they've been stretched? 22 ft/lbs doesn't sound like enough for critical bolts like this.
