Old September 27th, 2019, 07:16   #1
Withkids
TDI(s): Non yet
Default Spec flywheel
Has anyone tried a Spec sa01s flywheel? Can't find much information on it, except that it weighs 16 lbs. Which I know is a little light. I can get one cheap but wondering what size clutch it takes and if I can use my original starter. 05 Passat tdi if wondering.
Sent from my SM-G935P using Tapatalk
Withkids is offline   Reply With Quote
Old September 29th, 2019, 07:50   #2
Withkids
TDI(s): Non yet
No answers?
Old September 30th, 2019, 10:19   #3
PickleRick
PickleRick's Avatar
Never seen any info on it. Does it fit a 1.8t b5 or b5.5 passat? Its a little light for a diesel
Nobody exists on purpose. Nobody belongs anywhere. We’re all going to die. Come watch TV.
PickleRick is offline   Reply With Quote
Old October 4th, 2019, 16:01   #4
Withkids
TDI(s): Non yet
What I found was 1.8t audi and passat. I know it's a little light. The seller claims it will take a 240 mm clutch. Only reason I'm interested in it.
Old October 4th, 2019, 17:57   #5
PickleRick
PickleRick's Avatar
Will need a starter spacer to work most likely.
Thus far my valeo 228 mm set up with the south bend upgrade is doing well.
Zero difference between the feel of the 20 lbs valeo and 30lbs Whitbread flyweel.
The Whitbread flyweel is 240mm and requires no spacer. If i could have gotten any other clutch manufacturer other than clutch masters to fit it id have stuck with the Whitbread. Matt is a great guy. Clutch masters however, their customer service sucks and that over priced fx300 is a pos.
Old October 4th, 2019, 18:53   #6
Withkids
TDI(s): Non yet
I have read your post about your clutch setup. Looks like the way to go. The flywheel was $75 and needed no spacer supposedly.
Old October 4th, 2019, 21:11   #7
Uberhare
Uberhare's Avatar
TDI(s): Too many.
Fuel Economy: Depends on what I'm towing!
Spec flywheels used to be made by Findanza, don't know if they still are. I've seen plenty of cracked ones on gas engines and would not even consider one for a TDI.
2004 Passat W8 Variant, awaiting BHW swap
Retired: 2005 Passat BHW Variant w/01E 6 gang
Uberhare is offline   Reply With Quote
Old October 6th, 2019, 05:41   #8
thundershorts
Withkids, if you are working on a b5.5, I have lots stuff for them no flywheel though. I'm only 5 miles away so feel free to pm me.
"You can't argue with a fool..."
thundershorts is offline   Reply With Quote
Sachs SMF Flywheel Bolt Torque Spec coolvdub TDI 101 3 July 12th, 2014 19:18
kevlar spec clutch/flywheel used. stage 2 jasonTDI Private TDI Items for Sale/Wanted 3 July 5th, 2010 14:02
Anyone have SPEC clutch AND flywheel? 2footbraker TDI Power Enhancements 9 December 24th, 2006 19:24
SPEC Flywheel - stock clutch? 2footbraker Upgrades (non TDI Engine related) 4 October 16th, 2006 21:18
Spec flywheel? ZuberSpeed TDI Power Enhancements 1 January 26th, 2004 16:34
Page generated in 0.13990 seconds with 11 queries
[Output: 83.23 Kb. compressed to 71.33 Kb. by saving 11.90 Kb. (14.30%)]
