Looking for thoughts on which direction to go as I am at a decision point for my daily driver. Some of you may have faced a similar choice before, curious to hear what you did if so.
I currently have two fairly similar TDI sedans and only need one. Both are black on black, GLS trim with leather and sunroof, higher miles but very good overall condition. I drive around 90 miles a day round trip in a highway commute that includes a mountain pass, so comfort, safety, economy, reliability are what I care about most.
The first is my 2001 Jetta. ALH, 5-speed, 344k miles as of today. This is a trusted car that has served me well for years, bought it back in 2014 and it has been my daily driver most of the time since then. Runs perfectly, T4 injectors and stock tune, great mileage, interior and exterior have held up beautifully, still very much enjoy driving it. I did the timing belt at 315k along with whatever other upkeep it needed (LCAs, brakes, etc), it will need a set of tires before next summer, otherwise nothing.
The second is my 2004 Passat. BHW with geared BSM conversion, 5-speed GGB (same as FHN) trans swap, 300k. Third gear synchro is broken in the transmission and the clutch is too aggressive for my preference, but otherwise this car is also in excellent condition. Major problem areas have been dealt with, turbo, cam/lifters, geared BSM, motor mounts, tandem pump, front suspension and brakes are recent, new parts all over the engine and car, timing belt done 25k ago. Kerma tune, has more power than I need. I bought this car the way it is with the intention to use the fully sorted and tuned engine in an Audi swap project. But I'm considering going a different direction with the Audi and also have decided this Passat is too nice to take apart. It drives well, looks and feels good, and seems to have a lot of good life left. All it needs is a transmission and maybe a different clutch.
So now I have a decision to make. I didn't plan on owning the Passat for the long term but since I have had it and spent some time driving it (including back to MT from CO where I bought it), it has grown on me, particularly the interior size with a much more usable back seat, and the greater quietness and refinement vs the Jetta. The downside of the Passat is that it needs an immediate repair, and the running costs will be higher with a few less MPG and a more complex BHW engine and B5 chassis.
As for the Jetta, the upsides are that it needs nothing, is still in great shape, and is a known quantity -- always has run well and probably always will. Simpler, lower running costs, cheaper parts, and less fuel use. But, the interior size is more of a limitation now than it used to be, and the smoothness and silence of the Passat on the highway makes the Jetta feel more crude by comparison.
Opinions? Is the higher cost and effort to keep the Passat on the road worth the benefit in the driving experience and interior space? Or is the reduced interior space and refinement a better tradeoff for the reliability and low running cost of the Jetta?
