3.9 Warranty: Defendants must provide an Emission Control System and an Engine
Long Block warranty (collectively, the “Extended Emissions Warranty”) for each Subject 3.0
Liter Vehicle receiving an Approved Emissions Modification. The Extended Emissions
Case 3:15-md-02672-CRB Document 2520-1 Filed 12/20/16 Page 122 of 164
21 APPENDIX B TO SECOND
PARTIAL CONSENT DECREE
MDL No. 2672 CRB (JSC)
Warranty shall cover all parts and labor, as well as the cost or provision of a loaner vehicle for
warranty service lasting longer than 3 hours. Defendants must not impose on consumers any fees
or charges, and must pay any fees or charges imposed by its dealers related to the warranty
service. The Extended Emissions Warranty shall provide warranty coverage as follows.
3.9.1 The Emission Control System warranty must cover the entire emission
control system including (1) all components that are replaced, repaired, installed,
upgraded, or otherwise modified as part of the Approved Emissions Modification; (2) all
components listed in subparagraphs 3.9.1 and 3.9.2; (3) and any other component that can
reasonably be impacted by effects of the Approved Emissions Modification. The
Emission Control System warranty must cover, at a minimum, the following parts:
i. The entire exhaust aftertreatment system including the DOC, the DPF, the
SCR catalyst, the dosing injector and other DEF system components, all
sensors and actuators, and any exhaust flap;
ii. The entire fuel system, including the fuel pumps, high pressure common
rail, fuel injectors, and all sensors and actuators;
iii. The EGR system including the EGR valve, EGR bypass valve, EGR
cooler, EGR filter, all related hoses and pipes, and all sensors and
actuators;
iv. The turbocharger system including all related hoses and pipes, all sensors
and actuators;
v. The OBD System and any malfunctions detected by the OBD systems;
and
vi. The ECU and the TCU.
3.9.2 The Engine Long Block warranty must cover the engine sub-assembly that
consists of the assembled block, crankshaft, cylinder head, camshaft, and valve train.
3.9.3 The warranty period for the Extended Emissions Warranty shall be the
greater of:
i. 10 years or 120,000 actual miles whichever comes first; and
ii. 4 years or 48,000 miles, whichever comes first, from date and mileage of
implementing the Emissions Modification, except for vehicles offered for
resale, in which case, from the date and mileage of the first resale
transaction after the modification to the first person who in good faith
purchases the vehicle for purposes other than resale.
