Hey Guys
I could still use some help with this code. I scanned it again today and the posted results are below. I would appreciate any help or suggestions provided. I had the new software recall performed and the dealer would not scan and check the code without me providing them 160. If it was under warranty they would have covered it but if not then I was out the 160.
One other question I have is about the AdBlue. I got the 1500 mile warning and added 2.5 gallons up when the 600 mile warning came on. How long does it take for the warning to go away? I have only driven it about 10-15 miles and started it multiple times today and it is still there. Tomorrow I will be talking it on a 65 mile drive one way and then back so hopefully that will do it.
Sunday,05,April,2015,18:16:34:02874
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.1.1 (x64)
Data version: 20150130
Mileage: 99740km-61975mi Repair Order: 4/5/2013
Chassis Type: A3 (7N0)
Scan: 01 03 08 09 15 16 17 19 1C 25 42 44 46 4F 52 56 62 72 77
VIN: Mileage: 99740km-61975miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CKRA) Labels: 03L-906-012-CKR.clb
Part No SW: 03L 906 012 DD HW: 03L 907 309 S
Component: R4 2,0L EDC H23 8400
Revision: 71H23--- Serial number:
Coding: 00190012042400000000
Shop #: WSC 56094 001 1048576
ASAM Dataset: EV_ECM20TDI01103L906012DD 004008
ROD: EV_ECM20TDI01103L906012DD.rod
VCID: 69D907128872D869D9E-803C
1 Fault Found:
5120 - Oxygen (Lambda) Sensor B1 S1
P2196 00 [237] - Signal too High (Rich)
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 90860 km
Date: 2015.02.01
Time: 15:13:08
Readiness: 1 1 0 0 0
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: C54BC0F5492800FFA31103EC921C0042A71000
Shop #: WSC 09003 957 00200
VCID: 7DF14342E4FA54C9056-8028
No fault code found.
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 561 907 426 A HW: 561 907 426 A
Component: AC Manuell H02 0101
Revision: 00001K07
Coding: 0010001002
ASAM Dataset: EV_ACManuaElectGen2BHTC 001002
ROD: EV_ACManuaElectGen2BHTC_VW36.rod
VCID: 193977D2189288E989E-804C
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 085 S HW: 5K0 937 085 S
Component: BCM PQ35 B+ 021 0068
Revision: BH021001
Coding: 6F200E18902B08D408880001160004C80071008650801560648060000C70
VCID: 4385F5BAC29EE239332-8016
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5C0 959 655 HW: 5C0 959 655
Component: AirbagVW10G 013 0809
Serial number: 003ENM04RK1S
Coding: 00003548
ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
ROD: EV_AirbaVW10SMEVW360_SK35.rod
VCID: 6FED690AB696365987A-803A
Seat occupied recognition:
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Component: BF-Gewichtss. H10 0046
Serial number: 6940000Y120000KY6C0%
Coding: 303044
Crash sensor for side airbag; driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H02 ----
Serial number: 3572MSME0F567471ZZZ
Crash sensor for side airbag; front passenger side:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H02 ----
Serial number: 3582MSME0D304572ZZZS
Crash sensor for side airbag; rear; driver side:
Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.H H02 ----
Serial number: 3516KSME4E59621FZZZ2
Crash sensor for side airbag; rear; passenger side:
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.H H02 ----
Serial number: 3526KSME1009721FZZZP
Crash sensor for front airbag; driver side:
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Fahr H02 ----
Serial number: 3556LSME651A771EZZZ2
Crash sensor for front airbag; front passenger side:
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME76666A1EZZZ8
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 1K5 953 521 AK HW: 5K0 953 569 B
Component: LENKS.MODUL 014 0140
Revision: FF010041 Serial number: 20120912200254
Coding: 008A140000
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 76E35C6EC9CC079144C-8023
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D
Component: E221__MFL-YVJ H07 0022
Coding: E20000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 561 920 970 E HW: 561 920 970 E
Component: KOMBI H07 0705
Serial number: 00000000000000
Coding: 231E01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 1C376EC617A0FDC1928-8049
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AH HW: 7N0 907 530 AH
Component: J533 Gateway H50 1634
Revision: H50 Serial number: 15101203290260
Coding: 461000
VCID: 76E35C6EC1CC079144C-8023
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 561 919 965 HW: 561 919 965
Component: Kompass 002 0001
Revision: 00002000 Serial number: 1829227R2YNV06
Coding: 0000002
VCID: 63C5153AA25E8239132-8036
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H07 0705
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: 6ADB781E8D74D371D04-803F
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0525
Revision: 13110009 Serial number: 0005591996
Coding: 0404F5
ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: 5BB52DDA522EBAF95B2-800E
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 HW: 561 959 811 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 004 4472
Serial number: --------------------
Coding: 800000
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 290 3305
Revision: 00H22000
Shop #: WSC 01357 011 00200
VCID: 377D916A4646BE999FA-8062
Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 7N0 907 530 AH
Component: EZE_2 H50 1634
Coding: 00000008
VCID: 6FED690ABE96365987A-803A
Subsystem 1 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 008 0005
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0525
Revision: 15110009 Serial number: 0005558598
Coding: 0404F4
ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 5CB72EC65720BDC1528-8009
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 HW: 561 959 812 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 004 4472
Coding: 800000
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AF HW: 1K0 035 180 AF
Component: Radio Prem-8 H04 0008
Revision: -----08S Serial number: VWZ4Z7M3376879
Coding: 0500040004000B
VCID: 64C7162667508501EA8-8031
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 106
Mileage: 89748 km
Time Indication: 0
Date: 2015.01.22
Time: 12:30:21
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007663449894
Coding: 0A10040000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA.rod
VCID: 3A7B885EBD54A3F1604-806F
End-------------------------(Elapsed Time: 02:30)--------------------------
