poormanq45
You'll need:Will this fit directly on a PD?
Can I just buy the cooler and seal or do I need longer bolts? I'm not sure what holds the cooler to the bottom of the oil filter housing.
I'm wanting the big cooler for the 130 passat
Cooler
Longer bolt
Seal
When I looked into this swap, I had a hard time finding the correct seal. I could only find the one that was round without the little "tangs" or "ears" on it. I'm not sure if those will work though.
