Old July 27th, 2020, 09:28   #1
tipsyskipper
TDI(s): 2002 Jetta
Default Recommendations for glow plug harness & glow plugs
My 2002 Jetta TDI 1.9L has been throwing the glow plug dash light warning since I've been driving it (January 2019). The glow plug harness is pretty ratty, the rubber insulation is cracked and breaking apart. I'm assuming that is what's throwing the code/illuminating the dash light. Just wondering if any of you have an opinion on what harness I should get to replace my existing one.
Is there a way to test glow plugs to check if they need to be replaced as well?
What are the symptoms of faulty glow plugs/glow plug harness?
I live in South Carolina, so cold isn't really an issue until late winter. But even then it's well above zero (Fahrenheit) and I haven't had any trouble starting the car despite the glow plug warning. TIA.
tipsyskipper is offline   Reply With Quote
Old July 27th, 2020, 09:52   #2
mr.loops
I just picked up an ALH glow plug harness from ID Parts - OEM too!
mr.loops is offline   Reply With Quote
Old July 27th, 2020, 09:52   #3
300D
https://www.idparts.com/glow-plug-an...lh-p-2059.html
But first a few notes:
Some people will recommend just ignoring it and keep trucking as sometimes the fix is more annoying than putting up with the little light.
Start by doing some testing before buying: http://forums.tdiclub.com/showthread.php?t=197941
If you do want to replace the plugs in the process, do your reading first. They can be persnickety little buggers. Don't try and force them out. Penetrating fluid and patience are your two best and only friends. The glow plug can be kind of twisted broken with too much force and will lead you down a painful rabbit hole. Don't ask me how I know.
300D is offline   Reply With Quote
Old July 27th, 2020, 09:53   #4
gforce1108
gforce1108's Avatar
Fuel Economy: Jetta: 44.5 summer / 47 on snows
Ohm to ground - should all be the same and pretty low (couple ohms). You can rig up connectors to make your own harness - I just buy the one from idparts are needed.
https://www.idparts.com/glow-plug-ha...20c-p-606.html
They also have a "kit" with the glow plugs
I hate rockauto.com http://forums.tdiclub.com/showpost.p...&postcount=236
04 Jetta GLS 5sp - EGR delete, RC3, VNT17/22, 3" turbo back exhaust & 2.5" FMIC+PD150 intake. SBC Stage 2 Endurance w/SMF and Peloquin LSD. Eibach lowering springs
gforce1108 is offline   Reply With Quote
Old August 1st, 2020, 18:16   #5
wonneber
If the harness is that bad it may need replacing.
There are a few things that can turn the glow plug light on.
I don't recall all the reasons.
The only problem I had ( and common ) was the glow plug blinking while going down the road.
Turned out to be both brake lights were burnt out one time and when I tried LED lights w/o load resistors.
I also had to replace the harness just after the car went out of warranty.
It did not look bad at all.
wonneber is offline   Reply With Quote
Old August 1st, 2020, 20:28   #6
KrashDH
TDI(s): 2002 Golf
Originally Posted by wonneber View Post
If .
You sure the LEDs actually failed?
I switched to LEDs. Everything works perfectly EXCEPT I have a flashing glow plug light. The ECU monitors both brake lights as a circuit. If it doesn't detect halogen power, resistance, or current (not sure which yet) then it will flash.
But the bulbs physically work fine.
I'm also using a 5th brake light LED in conjunction with the stock brake light. I think that's my problem because I'm running an error free canbus LED bulb IN the stock brake bulb location. Then with another LED in parallel, the math brings me outside of the scope of the stock halogen numbers.
I whipped up a calculator spreadsheet last night and ordered some different bulbs that SHOULD get me back close to the OEM numbers the ECU likes, to run in the 5th brake light position to test my theory...
Now I've gone completely in the weeds on this thread. Sorry OP
KrashDH is offline   Reply With Quote
Old August 1st, 2020, 22:22   #7
STDOUBT
STDOUBT's Avatar
Obligatory for posterity:
https://www.theartofdiesel.com/80-gl...not-on-my-tdi/
Volkswagen - turning owners into mechanics since 1938
STDOUBT is online now   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
volmaniac
glow plug wiring harness and plugs kml TDI 101 2 December 22nd, 2010 06:25
HELP!! $684 - glow plug harness and plugs Bopper VW MKIII-A3/B4 TDIs 22 June 5th, 2008 19:49
WTB: Glow plugs and glow plug wiring harness (01 Jetta) TDI_NC Private TDI Items for Sale/Wanted 2 January 5th, 2006 08:02
Glow plug CEL with new glow plugs and harness dslemaire VW MKIII-A3/B4 TDIs 6 November 9th, 2004 15:24
Glow Plug Relay & Glow Plugs gobucks VW MKIV-A4 TDIs (VE and PD) 4 December 12th, 2001 23:43
Page generated in 0.15451 seconds with 13 queries
[Output: 82.72 Kb. compressed to 72.27 Kb. by saving 10.45 Kb. (12.63%)]
