So i got my alh running in the 98 4runner but as soon as i touch the pedal it goes WOT. there is no brake switch hooked up as i thought i didnt need it. On VCDS pedal is always 65% then at full pedal it jumps to 85. Doesnt read anything in-between. I'm thinking i need the brake switch but i think there are other gremlins behind this.
Also is the brake switch wired directly to the ecu or is there a relay in there?
