ranchero76
So, folks, I bought it Will post more details later
https://forums.tdiclub.com/showthread.php?t=383273
I might throw VW cluster under the dash and take voltage for check engine light, glow plugs light etc. off it, unless I can locate these signals in the harness.
If your other gauges are working, your original chrysler ecu should be in there and functioning. CE and GP pin locations are correct for 2002 ALH. Not sure about other years. I am using LED, but I believe someone else is using incandescent with no problems.Thanks for the link! So CEL is on pin 24, glow plug light is on pin 40, am I correct?
Are you using LED or incandescent? Not sure if Dakota will help with tach as I don't even know for now in which state is original Caravan ECU ).
Yep I've been using incandescents in my swap since for over 30k miles with zero issues....If your other gauges are working, your original chrysler ecu should be in there and functioning. CE and GP pin locations are correct for 2002 ALH. Not sure about other years. I am using LED, but I believe someone else is using incandescent with no problems.
at what point does your CEL go off?...about 30 to 40 seconds after cranking?Ok, guys, will try to play with it, just need to find time . Not sure what they did with original ECU, as CEL goes off with no original motor present ))))).
So far - 700km, this thing has unbelievable fuel mileage
do you have the lamp connected directly to pin 24?...if so the lamp is functioning backward....on when no codes present and off when codes are present.... http://forums.tdiclub.com/showthread.php?t=3530833 sec after turning ignition on
