greyfoxxca
I am looking for a shop to do some repairs to my 2001 jetta. I am sure the dual mass flywheel is having problems as it shutters when starting off with low RPM. Smooth at 2000rpm. Not thinking it is the rear seal as it uses pretty well no oil. Talked to dealer and will not go with solid flywheel and I will not replace it with the same garbage. Has anyone in the area had good dealing with a shop around here could you give me a PM thanks. Not really keen on the dealer anyway as we have a 2014 tdi wagon in the garage.
