siznana
Not only does the brake light switch go, but my door lock cylinder is falling out! What did y'all do?!
No, I'm kidding, but seriously, I need some help here. The driver's side door lock cylinder is totally loose. I can just pull it out. I noticed it when getting into the car; it was sticking out a half inch from its mount. I see in the Bentley on page 57-5 and 57-6 there are some directions for removing/installing the cylinder housing. I believe that I popped off the correct cover and tightened the correct screw (with the T20), but the cylinder is still loose and able to fall out. The lock function is unaffected - both the remote and key still work when the cylinder is pushed back into place. Any thoughts?
