FlipOne513
I’m planning on ordering a Westfalia tow hitch with the dedicated electrics kit. After searching around on TDIclub I see a lot of write ups on how to use a 7 pin euro with a 7 pin USA connector. I’m not really sure why I would want to do that. The trailer I’m planning on buying has a 4 pin flat style connector. Can’t I Just use this Reese 7 pin Euro to 4 Pin flat adapter? https://www.amazon.com/Reese-118710-7-Way-European-Adapter/dp/B00IE41DIC
I’m planning on adding brakes to the trailer. Is that why I would need the 7 pin? All the write ups ive seen involve coding the module or ECU. Wouldn’t it just be easier to convert the trailer from 4 pin to 7 pin euro? Or run the trailer brake controller separately? I’m I missing something?
TL,DR. Can I use a Westfalia 7pin wire harness and a Reese 7pin euro to 4 pin flat adapter and have all my trailer lights work?
